OpenVPN settings help AC88u Firmware:380.66
akb
Could someone please give me a sample template for a very secure profile. So far I have everything as default, and I am not very familiar with TLS channel control and what the default auth digest is. It seems like whenever I change those values, I am not able to connect with OpenVPN clients. Sorry if this is a noob question, I just never had a need for VPN until recently since I am traveling a lot and want the security.
Hi Appreciate the links, I already found most online guides, which do not talk about the TLS channel encryption and how to set it up on ASUS. Also none of this mention what the default setting is, typically when something has default, it would look like "defualt (SHA256)". I want to know what the default value is and which values are better/supported with most devices.
Like mentioned I was able to get OpenVPN working, but mostly with the default values.
if u want to know more about those setting read OpenVPN documentation, there is everything very well described
