OpenVpn
enrico
Hi All,
I have an RT-AC65P router as an OpenVPN server in my home. At another place, there is an RT-N18U with Merlin firmware and a USB-attached external HDD. The N18U can connect as a client via OpenVPN to my AC65P. I need to access the HDD on the client from my server's subnet via ftps. (ftps share works in N18U's lan), but can't access from server's subnet. What should I set up?
Many thanks in advance!
Merlin has never made a firmware for the RT-N18U so you're probably using an unofficial port based on some old code. I suggest you contact the creator of the firmware directly as it's unlikely anyone here knows how your firmware works.
Thank you for your feedback. I understand the point, but assume OpenVPN should work in the same way on all devices. My question focused on OpenVPn settings available in Merlin firmware.
This is not the case. Merlin has made many changes that can effect the VPN over the years. Some of these effect routing and the firewall. What advanced options do you have for your VPN client and VPN server?
I got it.
Unfortunately, it doesn't. As I understand I should add something to Custom Configuration about routing, but I don't know what.
What IP address are you trying to connect to with your FTPS client?
Can you connect using a different protocol, e.g. SSH?
What is the output of this command:
iptables-save -t filter
What is the IP subnet address of the VPN server's LAN, VPN client's LAN, and the VPN client itself (your screenshot is too fuzzy to read).
Server subnet: 192.168.1.0/24
VPN clients LAN: 192.168.3.0/24 (by server)
Client's LAN 192.168.2.0/24 (by clients)
The client gets 192.168.3.6 from the server and its IP is 192.168.2.1
I have tried to connect to 192.168.2.1 and 192.168.3.5 too.
ASUSWRT-Merlin RT-N18U 386.3_2 Mon Oct 31 15:43:08 UTC 2022
admin@RT-N18U-0764:/tmp/home/root# iptables-save -t filter
# Generated by iptables-save v1.4.15 on Fri Mar 29 15:27:29 2024
*filter
:INPUT ACCEPT [0:0]
:FORWARD DROP [0:0]
:OUTPUT ACCEPT [1836:512174]
:ACCESS_RESTRICTION - [0:0]
:DNSFILTER_DOT - [0:0]
:FUPNP - [0:0]
:INPUT_ICMP - [0:0]
:INPUT_PING - [0:0]
:NSFW - [0:0]
:OVPN - [0:0]
:PControls - [0:0]
:PTCSRVLAN - [0:0]
:PTCSRVWAN - [0:0]
:SECURITY - [0:0]
:default_block - [0:0]
:logaccept - [0:0]
:logdrop - [0:0]
:other2wan - [0:0]
-A INPUT -p udp -m udp --dport 4672 -j ACCEPT
-A INPUT -p udp -m udp --dport 4665 -j ACCEPT
-A INPUT -p tcp -m tcp --dport 4662 -j ACCEPT
-A INPUT -p tcp -m tcp --dport 51413 -j ACCEPT
-A INPUT -p udp -m udp --dport 51413 -j ACCEPT
-A INPUT -d 192.168.1.135/32 -p tcp -m tcp --dport 8481 -j DROP
-A INPUT -d 192.168.1.135/32 -p tcp -m tcp --dport 8081 -j DROP
-A INPUT -p icmp -m icmp --icmp-type 8 -j INPUT_PING
-A INPUT -m state --state RELATED,ESTABLISHED -j ACCEPT
-A INPUT -m state --state INVALID -j DROP
-A INPUT ! -i br0 -j PTCSRVWAN
-A INPUT -i br0 -j PTCSRVLAN
-A INPUT -i br0 -m state --state NEW -j ACCEPT
-A INPUT -i lo -m state --state NEW -j ACCEPT
-A INPUT -m state --state NEW -j OVPN
-A INPUT -p udp -m udp --sport 67 --dport 68 -j ACCEPT
-A INPUT -p tcp -m tcp --dport 22 -j ACCEPT
-A INPUT -p icmp -j INPUT_ICMP
-A INPUT -j DROP
-A FORWARD -m state --state RELATED,ESTABLISHED -j ACCEPT
-A FORWARD ! -i br0 -o eth0 -j other2wan
-A FORWARD -i br0 -o br0 -j ACCEPT
-A FORWARD -m state --state INVALID -j DROP
-A FORWARD -j NSFW
-A FORWARD -i br0 -j ACCEPT
-A FORWARD -m conntrack --ctstate DNAT -j ACCEPT
-A FORWARD -m state --state NEW -j OVPN
-A FORWARD -j DROP
-A OUTPUT -p udp -m udp --dport 4672 -j ACCEPT
-A OUTPUT -p udp -m udp --dport 4665 -j ACCEPT
-A OUTPUT -p tcp -m tcp --dport 4662 -j ACCEPT
-A INPUT_ICMP -p icmp -m icmp --icmp-type 8 -j RETURN
-A INPUT_ICMP -p icmp -m icmp --icmp-type 13 -j RETURN
-A INPUT_ICMP -p icmp -j ACCEPT
-A INPUT_PING -i eth0 -p icmp -j DROP
-A PControls -j ACCEPT
-A SECURITY -p tcp -m tcp --tcp-flags FIN,SYN,RST,ACK SYN -m limit --limit 1/sec -j RETURN
-A SECURITY -p tcp -m tcp --tcp-flags FIN,SYN,RST,ACK SYN -j DROP
-A SECURITY -p tcp -m tcp --tcp-flags FIN,SYN,RST,ACK RST -m limit --limit 1/sec -j RETURN
-A SECURITY -p tcp -m tcp --tcp-flags FIN,SYN,RST,ACK RST -j DROP
-A SECURITY -p icmp -m icmp --icmp-type 8 -m limit --limit 1/sec -j RETURN
-A SECURITY -p icmp -m icmp --icmp-type 8 -j DROP
-A SECURITY -j RETURN
-A logaccept -m state --state NEW -j LOG --log-prefix "ACCEPT " --log-tcp-sequence --log-tcp-options --log-ip-options
-A logaccept -j ACCEPT
-A logdrop -m state --state NEW -j LOG --log-prefix "DROP " --log-tcp-sequence --log-tcp-options --log-ip-options
-A logdrop -j DROP
-A other2wan -i tun+ -j RETURN
-A other2wan -j DROP
COMMIT
# Completed on Fri Mar 29 15:27:29 2024
And this from the server (the previous is from the client)
# Generated by iptables-save v1.4.12.2 on Fri Mar 29 15:32:21 2024
*filter
:INPUT ACCEPT [0:0]
:FORWARD ACCEPT [414:25722]
:OUTPUT ACCEPT [7983:7766690]
:FUPNP - [0:0]
:INPUT_ICMP - [0:0]
:OUTPUT_DNS - [0:0]
:OUTPUT_IP - [0:0]
:PControls - [0:0]
:PTCSRVLAN - [0:0]
:PTCSRVWAN - [0:0]
:SECURITY - [0:0]
:logaccept - [0:0]
:logdrop - [0:0]
:logdrop_dns - [0:0]
:logdrop_ip - [0:0]
-A INPUT -i tun15 -j ACCEPT
-A INPUT -i tun21 -j ACCEPT
-A INPUT -p udp -m udp --dport 64565 -j ACCEPT
-A INPUT -i ppp0 -p icmp -m icmp --icmp-type 8 -j DROP
-A INPUT -d 192.168.1.1/32 -i br0 -p udp -m udp --dport 53 -m string --string "Instagram" --algo bm --to 65535 --icase -j DROP
-A INPUT -i pptp+ -m state --state NEW -j ACCEPT
-A INPUT -p tcp -m tcp --dport 21 -j ACCEPT
-A INPUT -p tcp -m tcp --dport 1723 -j ACCEPT
-A INPUT -p gre -j ACCEPT
-A INPUT -j DROP
-A FORWARD -i tun15 -j ACCEPT
-A FORWARD -i tun21 -j ACCEPT
-A FORWARD -i br0 -p udp -m udp --dport 53 -m string --string "Instagram" --algo bm --to 65535 --icase -j DROP
-A FORWARD -p tcp -m webstr--webstr Instagram  -j REJECT --reject-with tcp-reset
-A FORWARD -p tcp -m tcp --tcp-flags SYN,RST SYN -j TCPMSS --clamp-mss-to-pmtu
-A FORWARD -i pptp+ -j ACCEPT
-A FORWARD ! -i br0 -o ppp0 -j DROP
-A FORWARD ! -i br0 -o eth3 -j DROP
-A OUTPUT -p udp -m udp --dport 53 -m u32 --u32 "0x0>>0x16&0x3c@0x8>>0xf&0x1=0x0" -j OUTPUT_DNS
-A OUTPUT -p tcp -m tcp --dport 53 -m u32 --u32 "0x0>>0x16&0x3c@0xc>>0x1a&0x3c@0x8>>0xf&0x1=0x0" -j OUTPUT_DNS
-A OUTPUT -j OUTPUT_IP
-A FUPNP -d 192.168.1.67/32 -p udp -m udp --dport 57241 -j ACCEPT
-A FUPNP -d 192.168.1.218/32 -p tcp -m tcp --dport 8081 -j ACCEPT
-A OUTPUT_DNS -m string --hex-string "|10706f697579747975696f706b6a666e6603636f6d00|" --algo bm --to 65535 --icase -j logdrop_dns
-A OUTPUT_DNS -m string --hex-string "|0d72666a656a6e666a6e65666a6503636f6d00|" --algo bm --to 65535 --icase -j logdrop_dns
-A OUTPUT_DNS -m string --hex-string "|1131306166646d617361787373736171726b03636f6d00|" --algo bm --to 65535 --icase -j logdrop_dns
-A OUTPUT_DNS -m string --hex-string "|0f376d667364666173646d6b676d726b03636f6d00|" --algo bm --to 65535 --icase -j logdrop_dns
-A OUTPUT_DNS -m string --hex-string "|0d386d617361787373736171726b03636f6d00|" --algo bm --to 65535 --icase -j logdrop_dns
-A OUTPUT_DNS -m string --hex-string "|0f3966646d617361787373736171726b03636f6d00|" --algo bm --to 65535 --icase -j logdrop_dns
-A OUTPUT_DNS -m string --hex-string "|1265666274686d6f6975796b6d6b6a6b6a677403636f6d00|" --algo bm --to 65535 --icase -j logdrop_dns
-A OUTPUT_DNS -m string --hex-string "|086861636b7563647403636f6d00|" --algo bm --to 65535 --icase -j logdrop_dns
-A OUTPUT_DNS -m string --hex-string "|076c696e77756469056633333232036e657400|" --algo bm --to 65535 --icase -j logdrop_dns
-A OUTPUT_DNS -m string --hex-string "|0f6c6b6a68676664736174727975696f03636f6d00|" --algo bm --to 65535 --icase -j logdrop_dns
-A OUTPUT_DNS -m string --hex-string "|0b6d6e627663787a7a7a313203636f6d00|" --algo bm --to 65535 --icase -j logdrop_dns
-A OUTPUT_DNS -m string --hex-string "|077131313133333303746f7000|" --algo bm --to 65535 --icase -j logdrop_dns
-A OUTPUT_DNS -m string --hex-string "|057371353230056633333232036e657400|" --algo bm --to 65535 --icase -j logdrop_dns
-A OUTPUT_DNS -m string --hex-string "|077563746b6f6e6503636f6d00|" --algo bm --to 65535 --icase -j logdrop_dns
-A OUTPUT_DNS -m string --hex-string "|0e7a786376626d6e6e666a6a66777103636f6d00|" --algo bm --to 65535 --icase -j logdrop_dns
-A OUTPUT_DNS -m string --hex-string "|0a65756d6d6167766e627003636f6d00|" --algo bm --to 65535 --icase -j logdrop_dns
-A OUTPUT_IP -d 193.201.224.0/24 -j logdrop_ip
-A logdrop -j DROP
-A logdrop_dns -j LOG --log-prefix "DROP_DNS " --log-tcp-sequence --log-tcp-options --log-ip-options
-A logdrop_dns -j DROP
-A logdrop_ip -j LOG --log-prefix "DROP_IP " --log-tcp-sequence --log-tcp-options --log-ip-options
-A logdrop_ip -j DROP
COMMIT
# Completed on Fri Mar 29 15:32:21 2024
The iptables output from your VPN client looks like the client isn't turned on? Is that the case?
Indeed. It connects now.
# Generated by iptables-save v1.4.15 on Fri Mar 29 15:51:28 2024
*filter
:INPUT ACCEPT [0:0]
:FORWARD DROP [0:0]
:OUTPUT ACCEPT [885:810324]
:FUPNP - [0:0]
:INPUT_ICMP - [0:0]
:INPUT_PING - [0:0]
:NSFW - [0:0]
:OVPN - [0:0]
:PControls - [0:0]
:PTCSRVLAN - [0:0]
:PTCSRVWAN - [0:0]
:SECURITY - [0:0]
:logaccept - [0:0]
:logdrop - [0:0]
:other2wan - [0:0]
-A INPUT -j DROP
-A FORWARD -j NSFW
-A FORWARD -j DROP
-A OVPN -i tun11 -j ACCEPT
-A logdrop -j DROP
COMMIT
# Completed on Fri Mar 29 15:51:28 2024
