I beat most of the lag
I beat most of the lag.
How?
I disabled WMM in Wireless Settings. (2.4 GHz and 5 GHz professional TAB) I don´t play Wireless but THIS setting caused all the lag. I don´t know if WMM is always running or how it works excatly - but with disabled WMM it´s the first Time I can play Call of Duty off and on Host - I´m not behind anymore.
Is it possible that WMM is always running? Even if I don´t play wireless?
I think:
It´s like QOS and it seems to run all the time. If you host games then there are too many connections to handle (xbox is p2p) - you are behind.
If you want to beat LAG then disable this feature - even if you don´t play wireless.
Thank you bro. I have many problems with lag but on PS4. I change my settings like you say. I have Asus RT- N14U with Padavan
update. WMM - disable, WAN -Offload TCP/UDP for LAN - disable ( slow ). In Uncharted 4 multiplayer i have NO LAG, hitmarkers now very correct. Thank you very much
