Hi, i don't know if this is the best place to ask, it's the best i've come across. If there is another place i would be better at to get this information, please forward me on.
I've recently got a Asus AC56U Router on which i have installed the Merlin Firmware. I would like to be able to run Sabnzbd from it as the usenet client built in to the firmware is lacking in features.
How i understand it, it is possible to do such a thing by first installing download master and then uninstalling it, that puts optware on the router allowing me to go ahead with the installing of sabnzbd but that's where i get stuck.
Guide 1
http://linksysinfo.org/index.php?threads/setup-usenet-client-with-optware.37963/
On this guide i run in to various errors.
Guide 2
http://www.acryan.com/forums/viewtopic.php?f=41&t=3464
I know this guide isn't specifically designed for my router but it was worth a try, that guide seems to be work and the service even starts but trying to access the page with 192.168.1.1:8080/sabnzbd/ simply doesn't work, it's like nothing is running.
Other Information
I'm using a Mac but can access a Windows PC which is what i've used to create a Ext4 2gb Partition for optware. I'm using terminal to ssh to the router which i can do but have little experience in linux based systems so i'm limited to commands that i read in guides. It might be that the guides im using simply will not work with my router, if that's the case could anyone suggest a good usenet client that i could maybe get to work?
If you need any more information just ask. Thank you in advance.
Guide 1
Guide 2
Other Information
