ascanio1
To start with I congratulate and thank you for the great forum, reviews and also for the generally cheerfully & helpful attitude of the community.
I apologize for being IT dumb (not just challenged) which, I am sure, will annoy quite a few as the answer is certainly somewhere in here in the forum or reviews, and I simply have been unable to find/understand it.
I need advice on how to setup an access point for a garden.
Are there waterproof routers? Do I need to install them in a casing? What type of casing? Where can I find it?
Any other requirements as antennas, booster, etc?
Could you also point out resellers for these items/accessories?
Can you recommend a **** very reliable **** AC router/AP that has sufficient power to cover a 200mt radius (some trees but no buildings)?
Throughput would be a plus (but reliable is a must) as we would stream Vudu 1080p films at about 120mt from the AP, where the pool is situated.
Please note that the property is in the middle of nowhere and I can tweak the power, the antennas, etc, without incurring into legal/neighbour problems. I would ask a friend (I'm unable) to flash an appropriate firmware, if necessary, to increase power (although I read somewhere that increasing only transmit power is not enough as packets or some other data has to be transmitted back to the AP, even during download).
Whilst I'm at it, I would also appreciate if you would name a couple of AC APs (or routers) for inside the home itself (in 6 rooms each one cabled with shielded cat 6). I seek these 2 qualities in this order:
- reliable
- throughput
I have been quite happy with an Asus RT-AC66U but I'm open to advice.
Again I apologize but the AP review is too complex with too many tweaks for me to understand easily, given my IT ignorance. I thank in advance anyone willing to share his time and expertise.
Tommaso
Sent from my MHA-L29 using Tapatalk
- reliable
- throughput
Tommaso
