Pavadan Firmware PIA losing script
Rick Mathes
I am running pavadan firmware on my Asus Rt-N56u router with PIA as my vpn provider. It's working fine except one problem. If I unplug the router or it loses power when it goes back on I no longer am connected to the vpn. My problem is when I go in to the gui I get message ssl/tls certificate not found and sure enough it's not there. I can add it again and everything is fine until next time power removed. Any suggestions. Thanks in advance.
Never mind. Finally found the answer. Here it is just in case someone else runs in to the same thing.
In order to save or preserve your certificates, you need to perform this, under Administration->Console, type "mtd_storage.sh save"
