PBR rules going away
Res Cogitans
I'm having a recurring problem with policy-based routing rules disappearing. My rules are set up by a simple openvpn client route-up script:
admin@RT-AC68U:/jffs/scripts# cat route-up.sh
#!/bin/sh
ip route add default via $route_vpn_gateway dev $dev table 42
ip rule add from 10.10.10.11 lookup 42
This works fine. The problem is that after a while, usually overnight, the ip rule just goes away:
admin@RT-AC68U:/jffs/scripts# ip rule
0:      from all lookup local
32765:  from 10.10.10.11 lookup 42
32766:  from all lookup main
32767:  from all lookup default
# --- overnight time gap here
The VPN connection stays up the whole time. Any ideas what might be going on?
3.0.0.4.376.48_1 on a RT-AC68U.
Thanks.
