Unfortunately I‘m facing problems with the combination of pihole, unbound and VPN.
Pihole‘s IP ist set under LAN -> DHCP Server -> DNS & WINS
Forthermore Pihole is set in DNSFilter as Router
I‘ve configured pihole to use unbound for resolving (127.0.0.1)
I‘m using VPN director to put selective devices into the VPN tunel
Everything works fine as long as pihole ist outside of the VPN tunel. But if it‘s outside the VPN tunel I get a DNS leak when I check on dnsleak.com. When i try to put the pihole into the von tunel (through routing policy) I see servfail in the pihole log. This problem disappears when I use external dns for resolving (either in pihole configuration or via forward zone in unbound config)
Has someone faced such problems and maybe can help me out? I don‘t want to use external/public DNS server.
Many thanks in advance.
