Plex server on R9000 X10 - adding a custom channel?
psychopomp1
On stock fw 1.0.2.40 and Plex Server v1.9.2.4285 on the X10, does anyone know how to add a custom TV channel list into the Plex Media Server? I have a .bundle folder on my USB drive (plugged into X10) and I believe this needs to go inside
%LOCALAPPDATA%\Plex Media Server\Plug-ins\
where/how do I find this directory on the X10?
Cheers
Hi...
For the current version, I understand this is located in /tmp/plexmediaserver/1.9.2.4285-9f65b88ae/Resources/Plug-ins-9f65b88ae/
However, this is Plex specific and not controlled by the R9000 GUI.
Also, Plex uses its own GUI developed by Plex (enclosed sources, own GUI, own system of customisation).
Further information regarding adding own channel at: https://support.plex.tv/hc/en-us/articles/201187656-How-do-I-manually-install-a-channel-
Thanks Netgear Guy, so how would I access
and put my .bundle folder inside that, bearing in mind that the Plex server is running on the R9000? Telnet commands?
Will need to verify the folder name, but understand this was the location (Plex specific)
Yes, it would be Telnet commands.
You will need to login to the R9000 GUI and enter the following: "<R9000 IP address>/debug.htm" then click "Enable Telnet" and run a Telnet client on a PC
