-PLS HELP- Port Speed negotiation problem 384.13_4 AC3200
JPP PPJ
After flashing my AC3200 with 384.13_4 PORT LAN 2 is unable to negotiate 1000FD. Below is what I have done. LAN2 is stuck in 100HD
  1. I moved the cable on LAN 2 to each of the other port, LAN 1, LAN 3 and LAN 4 and it was able to negotiate 1000FD
  2. I moved each of the cables on LAN 1, LAN 3 and LAN 4 to LAN2 and every single device attached to those cables could not negotiate 1000FD only 100HD. Once I moved to their original port they negotiated 1000FD
  3. Factory Reset the router and manually configured the router - Same problem no success
  4. Reflashed the routed with 384.13_4 - Same problem no success still stuck 100HD
  5. Factory reset and used the recovery ASUS tool, firmware restoration, to upload 384.13_4 . Then used default config, I just set up password and SSID - Same problem no success still stuck 100HD
  6. SSH into the router and played with the nvram setting port#vlans to forced auto negotiation and hardcoded to 1000FD - Same problem no success still stuck 100HD
  7. SSH into the router and tried to forced the port with the robocfg command. I can disable the port, enabled it and set the media to auto but same problem no success still stuck 100HD
I was trying to use the "et" utility/command line but it seems I do not have the right syntaxsis and no information online.
It seems the negotiation capability or feature on LAN 2 is off or the port is bad which would be strange. I see also another user reporting a problem with negotiation on port connected to a ubiquiti switch, the problem seems similar.
Can some please send me or point me to et command line instructions with the right syntaxsis? or share if you have experienced a speed negotiation problem with the latest version?
I have not tried to change the version yet.
