Port Forward not working when vpn is enabled
jjulez
Any ideas what going on this never happen before i'm stump.
Running RT-AC86U merlin 384.18..PIA is setup in router
I am not doing anything special just a regular vpn setup.
All i know is when the vpn is enabled port forwarding don't work
Should we guess your setup?
  1. You have PIA setup as the only VPN client?
  2. Is the router traffic using the VPN or WAN in the VPN client routing rules?
  3. What external port are you trying to forward?
PIA is the only client.
For now router traffic is going through WAN , rules will come after the dust is settle
port 8096
As i said port forwarding works once the VPN is not on
