David Partridge
I've just installed Xwrt-Vortex 380.66_2 onto a Netgear R7000 which replaces a BT Homehub 5A running LEDE which didn't have the processing power to support a VPN.
The OpenWRT VPN policy based routing written by "stangri" is easier to use for destination sites as you specify the target website using its DNS name (e.g. http://speedtest.btwholesale.com/) rather than needing to specify IP addresses or (in this case) two separate IP subnets (193.113.4.152/30 and 193.113.8.192/30). The advantage is two-fold:
I'd like to ask Merlin if he would liaise with "stangri" to bring this capability over to AsusWRT and therefore for Xwrt-Vortex.
Thanks a lot
Dave
- You are insulated from IP address changes for the domain (if they add/remove/change servers).
- You don't need to worry about specifying routing using IP subnets
Thanks a lot
Dave
