PPTP connection drops after "save"
al_n
Hello,
I'm using an RT-AC68U with v380.61 (latest).
I'm using time scheduling to block my children devices on certain times. Often I need to connect remotely over PPTP to switch time scheduling on or off.
After hitting the "save" button and watching the progress reaching 100% the connection over PPTP will always drop. In order to verify my last action I have to disconnect and reconnect again.
Anyone knows how to fix this annoying behaviour?
If changing parental control parameter, you are changing firewall rules, which requires restarting various network components. This is a technical limitation, there's nothing you can do about it.
