PPTP VPN issue, not working
kinglevel
Hi
I think it was after the 378 major (The "Factory reset") release that i got some VPN struggle.. So what i did was to update to 378.53 and did another factory reset after that. Problem still remains... :(
I used to use openvpn, but after all resets, i tried to set everything up as simple as possible to try pptp, and this is my log
haaaaaalp
RT-AC68U, 378.53.
OSX 10.10.2, built in vpn client.
May 17 21:53:00 pptpd[5004]: CTRL: Client ****CLIENT-IP**** control connection started
May 17 21:53:00 pptpd[5004]: CTRL: Starting call (launching pppd, opening GRE)
May 17 21:53:00 pptp[5005]: Plugin pptp.so loaded.
May 17 21:53:00 pptp[5005]: PPTP plugin version 0.8.5 compiled for pppd-2.4.7, linux-2.6.36.4
May 17 21:53:00 pptp[5005]: pppd 2.4.7 started by admin, uid 0
May 17 21:53:00 pptp[5005]: Using interface ppp10
May 17 21:53:00 pptp[5005]: Connect: ppp10 <--> pptp (****CLIENT-IP****)
May 17 21:53:30 pptp[5005]: LCP: timeout sending Config-Requests
May 17 21:53:30 pptp[5005]: Connection terminated.
May 17 21:53:30 pptp[5005]: Modem hangup
May 17 21:53:30 pptp[5005]: Exit.
May 17 21:53:30 pptpd[5004]: CTRL: Client pppd TERM sending
May 17 21:53:30 pptpd[5004]: CTRL: Client pppd finish wait
May 17 21:53:35 pptpd[5004]: CTRL: Client ****CLIENT-IP**** control connection finished
It's kind of a generic error - what it means is that the pppd didn't get LCP config requests from the peer (your client)...
Check your client config, also, if the PPTP server is behind another router, then you can run into issues with GRE packets, but generally...
Check here for more info - http://pptpclient.sourceforge.net/howto-diagnosis.phtml#lcp_timeout
sfx
ok... After some reading, i am suspecting my ISP.. My setup have been working for more than a year, so it does not makes any sense why it should stop working with this kind of problem.
I can successfully connect within my own lan from a laptop, but not outside.
If you has setting DMZ server...
It will not working
I get DMZ server in my rt-ac66u & rt-ac87u is not work
Remove then, PPTP will work
Sounds more like a local issue then with your server and client... check ports being forwarded...
It will not working
Thanks to all your help.
I have found the issue
My cellphone ISP has made their cellular network to a non-NAT network, without noticing the customers, so now no one can use VPN. Good stuffs
LOL, i called the support and stirred the office... Now they have realized what they have done, so they are calling me constantly to find a solution to tell me that they are working on the bureaucracy to solve my problem.
