Problem downloading certain files
  • Thread starter Thread starter TheVegas
  • Start date Start date
T
TheVegas
Guest
I was using firmware 380.57 and sometimes when I try to download large files (>100mb) the download will get most of the way and then I get a failed unknown network error in chrome. It also fails in other browsers and on my other computers (windows and mac). It doesn't happen with all files. For instance I had trouble downloading an update for Turbotax (https://ttlc.intuit.com/questions/1...s-software-basic-deluxe-premier-home-business) but no problem downloading firmware 380.58. While I was updating to 380.58 I first used the nvram-save tool (version 22) to back-up my settings and then did a factory reset before updating the firmware. Before restoring my settings using the nvram-save tool, I tried downloading the turbotax update and it downloaded fine. However, after restoring my settings using the nvram-save tool, the download once again fails. Since downloads work on a freshly factory reset router, any idea what router setting is causing this to fail?
