Problem Installing Pixelserv-tls through AB Solution
DoctorDERP
I'm having some trouble installing Pixelserv-tls through the menu in AB Solution. I have Entware installed. My DHCP server assigns addresses from 100 to 199 and my NAS is on 250. I tried with the 240 address and get the same error. Has anyone else experienced this? Any solutions?
 AB-Solution 3.10.0: pixelserv-tls install
 pixelserv-tls server stats not available,
 trying to start pixelserv-tls again, with verbose output:
 stopping pixelserv-tls
 Checking pixelserv-tls (AB-Solution)...              dead.
 removing pixelserv-tls virtual IP 192.168.1.2
 starting pixelserv-tls virtual IP 192.168.1.2
 writing the pixelserv-tls startup script
 restarting pixelserv-tls to apply changes
 Starting pixelserv-tls (AB-Solution)...              done.
 trying to get pixelserv-tls server stats, in verbose mode:
--2017-12-05 14:52:25--  http://192.168.1.2/servstats.txt
Connecting to 192.168.1.2:80... failed: Connection refused.
Retrying.
--2017-12-05 14:52:26--  (try: 2)  http://192.168.1.2/servstats.txt
Retrying.
--2017-12-05 14:52:28--  (try: 3)  http://192.168.1.2/servstats.txt
Retrying.
--2017-12-05 14:52:31--  (try: 4)  http://192.168.1.2/servstats.txt
Retrying.
--2017-12-05 14:52:35--  (try: 5)  http://192.168.1.2/servstats.txt
Retrying.
--2017-12-05 14:52:40--  (try: 6)  http://192.168.1.2/servstats.txt
Giving up.
 at 192.168.1.2/servstats.txt
 You now have three options:
 1. Abort installation, to continue again from here
 2. Abort installation and reset pixelserv-tls settings
 3. Continue anyway, forcing the install
 Select what to do: [1-3]
Sorry can't help on this installation issue but I can offer some general recommendation.
If your NAS supports Entware-ng, you'd be better off running pixelserv-tls standalone there. The CPU speed in NAS is generally faster than a router. Hence, you'll get much better performance out of pixelserv-tls and a smoother browsing experience.
AB-SOLUTION is like a religion. There is a big & dedicate thread to its support. You'd better ask there :)
btw thanks for trying pixelserv-tls.
[ "thelonelycoder" = "Pope" ] && echo Argh! || echo Phew!
Is there another service listening on port 80 besides the router WebUI @DoctorDERP ?
This shows the output of netstat -tuln | grep :80, only pixelserv-tls and the WebUI listen on port 80:
user@RT-AC87U:/tmp/home/root# netstat -tuln | grep :80
tcp        0      0 192.168.2.2:80          0.0.0.0:*               LISTEN
tcp        0      0 127.0.0.1:80            0.0.0.0:*               LISTEN
tcp        0      0 192.168.2.1:80          0.0.0.0:*               LISTEN
Nope. Nothing else is listening on port 80. Any possibility that there's some kind of conflict or error in one of the config files?
Use the dedicated thread, thanks.
