SLK350
I'm having a really weird issue . When I try to set any channel above 112 "channel bandwidth" drops from 80 MHz to 40MHz or 20MHz. When I look at the setting it's 80MHz but when I switch to "wireless log" it says 20 or 40MHz. Also when setting channel 112 it still shows 112 in the listbox under 5GHz settings, but when I try to set any channel above 112 it changes to auto in the listbox but shows correct channel under "wireless log",
I have tried different firmwares and reset to defaults but nothing helps. Currently using 9.0.0.4.380_2339 firmware.
Channel 112, wifilog.
Channel 140, wifilog.
SSID: "Asus_5G"
RSSI: 0 dBm SNR: 0 dB noise: -92 dBm Channel: 112/80
BSSID: 1C:B7:2C:75:89:9C Capability: ESS
Supported Rates: [ 6(b) 9 12(b) 18 24(b) 36 48 54 ]
VHT Capable:
Chanspec: 5GHz channel 106 80MHz (0xe36a)
Primary channel: 112
HT Capabilities:
Supported MCS : [ 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 ]
VHT Capabilities:
Supported VHT (tx) Rates:
NSS: 1 MCS: 0-11
NSS: 2 MCS: 0-11
NSS: 3 MCS: 0-11
NSS: 4 MCS: 0-11
Supported VHT (rx) Rates:
NSS: 1 MCS: 0-11
NSS: 2 MCS: 0-11
NSS: 3 MCS: 0-11
NSS: 4 MCS: 0-11
Mode : AP Only
SSID: "Asus_5G"
RSSI: 0 dBm SNR: 0 dB noise: -89 dBm Channel: 140
VHT Capable:
Chanspec: 5GHz channel 140 20MHz (0xd08c)
Primary channel: 140
HT Capabilities:
VHT Capabilities:
NSS: 1 MCS: 0-11
NSS: 2 MCS: 0-11
NSS: 3 MCS: 0-11
NSS: 4 MCS: 0-11
NSS: 1 MCS: 0-11
NSS: 2 MCS: 0-11
NSS: 3 MCS: 0-11
NSS: 4 MCS: 0-11
Mode : AP Only
