Problem with OpenVpn-server on RT-AC3200 Asus merlin
hytekk
I´m trying to setup my own openvpn-server and following this guide:
https://github.com/RMerl/asuswrt-merlin/wiki/Generating-OpenVPN-keys-using-Easy-RSA
Everything works fine setting up all the keys and certificates (have tried both on router and a ubuntu-computer, more or less the same result eg keys differ but everything else is the same).
The problem is when I´m do copy-paste my key/cert into the routers webgui - VPN - OpenVPN Servers - Advanced - Content modification of Keys & Certification -- Everything is ok but pasting in Server certificate. From what I understand I should copy all of server.crt beginning with:
"Certificate:
Data:
Version: 3 (0x2)
Serial Number: 1 (0x1)
Signature Algorithm: sha1WithRSAEncryption ......."
And ending with:
FQuI3/NLaDg++vsT2HA9CWkX8Jb25EW2nMfjQ5LGv75cIT008nwSUXSGBHNxUwOI
5GDT
-----END CERTIFICATE-----"
The problem is that there is a limit of characters (3499) and I have is around 5500 characters . That means it stops pasting around Signature Algorithm.
I found this http://www.snbforums.com/threads/openvpn-server-certificate-no-longer-fits.13404/ which in someway almost explains my problem (probably?) but I can´t figure out how to solve it.
Anyone can guide me?
I think only need to paste the lines between (inclusive)
-----BEGIN CERTIFICATE-----
Does that mean this information should be saved or completely replaced?
Certificate:
Data:
Version: 3 (0x2)
Issuer: C=TW, ST=TW, L=Taipei, O=ASUS, CN=RT-AC3200/emailAddress=[email protected]
Validity
Not Before: Jan 1 00:04:21 2015 GMT
Not After : Dec 29 00:04:21 2024 GMT
Subject: C=TW, ST=TW, L=Taipei, O=ASUS, CN=RT-AC3200/emailAddress=[email protected]
Subject Public Key Info:
Public Key Algorithm: rsaEncryption
Public-Key: (1024 bit)
Modulus:
00:9e:d3:b6:10:f3:c5:6d:73:ef:3e:e5:c3:15:cd:
c0:0a:9b:1d:d2:01:28:6a:a9:cb:1a:57:25:cf:88: ......"
Or is similar information (but mine) stored using base64 DER between:
The same information is available in the base64 code. It's just a text dump of it, for easier identification by the user who generated it.
