Problem with SMB from 384.8 and up
nobody
Hello All
My router AC68W. SMB protocols 1 and 2. Client Win10.
I've been using the USB Application-Network Place (Samba) Share for some time now (years). When I update from version RT-AC68U.384.7-2 to any of the newer versions; 384.8, 384.8_2, or 384.9 I get an error trying to create a directory on the share. A dialog box pops up and this is the error message "An unexpected error is keeping you from creating the folder. If you continue to receive this error, you can use the error code to search for help with this problem. Error 0x8007010B: The directory name is invalid". After I close the dialog box a new directory of "New Folder" was created. I use Windows Explorer and right click in the folder and select New -> Folder. I checked the log and nothing appears when I do this.
I have tried doing a hard reset on the newer firmware version and re-entered all my configuration data, and I still get the above error.
Hope someone can help.
Thanks.
