Promise NS4300N Access Issues
taorama
Hello all,
I hope this isn't a repeated question. I did search the forum, but didn't find the answer to my problem.
I've got a NS4300N that I've used for over a year now with NO problems. Now, however, I can't access the files with the Mac or Windows systems attached to the network. The Macs can SEE the NAS in Finder (shows up under SHARED), but when I try to connect, the connection fails. However, when I try to log in to the admin GUI in my web browser (using the SAME username/pass I used to login through Finder), the login works and I can administer the NAS. But NO file access. Even using the SmartNAVI application, the system sees the NAS, but can't get into it. I did a hard reset, still nothing even with default settings. I can SEE it, everything's green, but no access.
There were no changes to the system or network prior to this bug.
Any suggestions would be greatly appreciated!
Thanks!
login the NAS using webPASM and run a check file system on each drive?
A second way is to remove and plug-in the drive( while the NAs is on), login as admin to see if the drive is detected and run the check file system. you may have to repeat this step a couple time.
tt
The file systems all check out fine. I can access the files now on a Win box using SmartNAVI, but still no go on the Mac, even using SmartNAVI for OSX. I can log in on the Mac through PASM, but logging in with SmartNAVI or through Finder just hangs.
PinkFloydEffect Solved Cannot Access Shared Drive Over VPN General NAS Discussion 4
