[Q] AC68U pptp can't connect samba
ryu2964
here is my setting:
pptp enable
lan broadcast both
MPPE check
auto dns check
auto wins check
mru 1450
mtu 1450
client 192.168.1.80-89 (dhcp range 192.168.1.100-254)
enable VPN+DHCP connection yes
network place samba support yes
i can use this setting surf internet and the vpn client(android phone via 3g) ip show my adsl's ip.
use my phone ping 192.168.1.1 & 192.168.1.101(my pc ) is work. and PC ping 192.168.1.80 also work. but I just can't access my pc via samba.
windows firewall was disable , I can access pc via wifi even use wifi connect this vpn server. its really weird.
p.s. I can access pc via 3g connect to vpn at tp-link wr1043nd-DDWRT (now change to ac68u). so it should be the router's problem.
can anyone give me some suggestion? thanks a lot!
Hi
i have the same Problem and only with the AC68U.
seems like I'm not alone ;)
and here is my routing table after pptp client connected(via 3g)
Destination Gateway Genmask Flags Metric Ref Use Iface
192.168.1.80 * 255.255.255.255 UH 0 0 0 ppp10
168.95.98.254 * 255.255.255.255 UH 0 0 0 WAN
192.168.1.0 * 255.255.255.0 U 0 0 0 LAN
default 168.95.98.254 0.0.0.0 UG 0 0 0 WAN
hope this can help..
