qos bandwidth limitation not working correctly
safwan264
hi, i have 5G/LTE connection. My router has quectel RM551, its made by sumcomm. From this router i connect to ASUS RT-AX58U, the only purpose is to limit the speed of wifi for all house , as shown in settings picture of QOS. I have wifi on AP which is tp-link connected after ASUS. While i also have wifi on suncomm, which is only used for QUEST 2 eleven table tennis game. All this settings only for my table tennis game ping. But as you can see wifi from AP is only 8 mbps while wifi from 5G CPE is 36 mbps. Why the AP is not giving 25 mbps?
Try with Bandwidth Limiter. It can be applied to IP range.
Fast.com is quite inconsistent. Use different speed test, speedtest.net is popular.
