I'm trying to setup QoS and have found that apparently you can't use it for download speeds above 100Mb. If I set it to 300Mb, speedtest.net tops out at around 100Mb, if I turn QoS off, I can get 300Mb. Anyone else seen this issue?
What router? QoS is not compatible with HW acceleration, so some routers will be limited to 100-150 MB/s due to the CPU being unable to provide more throughput.
I'll turn off QOS and test again. That should tell me about hardware acceleration.
Thanks for the quick reply... I have the RT-AC66U
It's running 3.0.0.4.376.48_1
LOL, answered THAT question!
Turned off Adaptive QOS, ran Speedtest again, getting the same 130mbit/sec.
Core 1 1%
Core 2 1%
Actually, it occasionally blipped up to 1% from 0%.
I tried OpenVPN on the AC87, and was disappointed that it did no better than my DIR-825. But, of course, I am comparing apples and oranges, because I had the DIR-825 configured for IPSec VPN using StrongSwan on OpenWrt.
through an OpenVPN tunnel
Welcome To SNBForums
