QOS on RT-AC68U, multiple matches
sfatula
What happens if I have two rules for a source IP? Say, I want to match all traffic heading out to port 443 from a specific and give it low priority, but, all other traffic from that ip medium priority.
Does QOS apply in rule order, does it take the first match perhaps? So, if the low pri rule was first, it would use it? Or, is it the other way around or some other way?
What would be the correct sequence in other words for the above two rules.
The answer is it takes the first match, so, put most qualified match first, and, most general last.
