Skynet Quad 9 being blocked by Skynet
BreakingDad
Just an observation, quad 9 is suddenly blocked by skynet.
Anyone else got this?
I whitelisted it. Fixed
Don't really understand why DNS servers suddenly get blocked.
This is the danger of publicly updated blocklists, occasionally stuff is blacklisted by not so nice actors, or genuine mistakes.
I did not experience this. If you are so inclined, identify which list the ban came from.
firewall stats search manualbans
firewall stats search {IP address}
Unfortunately I have re installed skynet since this happened and no longer have that info. It now seems to have been globally whitelisted however
Skynet automatically whitelists WAN DNS.
I would try to track down which blacklist is blocking it. @Bill Woodcock might be interested to know.
firewall banmalware exclude firehol_level3.netset
Say I want to exclude this list. Do I have to rerun this command again after reboot?
No, this setting will persist for the life of the Skynet installation. I can't find the external forum post, but firehol_level3 has been described as appropriate for a development environment but not a production environment.
Is level 2 stricter or more lax than level 3? Skynet uses level 2 as well. Or do they pull from completely different bases and aren't built on one another?
Level 2 and level3 are roughly the same size with 20% overlap. They are not composed of the same lists.
But it does not matter. The pattern of false positives, obvious ones like localhost or Quad9, have been consistent for years now. I don't think it should be in the default Skynet group.
If someone could find an alternative composed of similar lists minus the false positives, that would be be great.
firehol_level3
Looks to have been whitelisted now: https://otx.alienvault.com/indicator/ip/9.9.9.9
