Hello,
I have an AiMesh system set up in my house, consisting of 2x RT-AC68U (1 ghz dual core version) and 1xAC-58U V3.
The house consists of 4 floors and the placement of the routers is as follows:
First RT-AC68U is in the basement, where the main internet connection is. It is also the main router.
Second RT-AC68U is on the first floor and the RT-AC58U is on the last floor. Everything is connected via ethernet.
The walls are pretty thick, and there is absolutely no wifi coverage on the 2nd and 3rd floors with this configuration.
I want to add 2 more routers to the system, to cover the 2nd and 3rd floor and I am considering getting 2xAX58U for each floor.
Here comes my question: The main router will remain the RT-AC68U, because the main internet connection can't be moved, and therefore the router has to stay in the basement. I don't want to put the AX58U there, because internet in the basement is rarely used. So my question is, will I be able to use the AX standard on the new routers, operating as nodes, if my main router remains the RT-AC68U? To be honest, I don't care that much about the new AX standard, but would be nice to have it.
I also wonder if the RT-AX58U will have as good, if not better coverage than the RT-AC68U. I am really happy with the latter, and was considering getting the AC86U, but I need the router to be wall mountable, so I landed on the AX58U.
Thanks in advance for any input.
