Question about vpn
unknownflip
does anyone know a step by step on how to setup the vpn for newbies? sorry if it's a beginner question i just wanna be able to login to my computer from afar using my router? :(
And if you're looking at PPTP VPN, Asus has a FAQ on their website.
thank you so much for the responses, just one last question...on the first guide do i ignore the installing of tomato and openvpn and skip to setting up openvpn?
Correct, unless you haven't replaced the original firmware yet, in which case you will want to flash my build first. Asuswrt-Merlin can be flashed like a regular Asus update.
