question on x88 log file
brianmsailing
Lots of invalid token freed, are these normal?
Jul 15 22:29:15 kernel: FPM Pool 0: invalid token 0x00958000 freed
Jul 15 22:32:03 kernel: FPM Pool 0: invalid token 0x026b0000 freed
Jul 15 22:33:45 kernel: FPM Pool 0: invalid token 0x00860000 freed
Jul 15 22:38:23 kernel: FPM Pool 1: invalid token 0x20d20000 freed
Jul 15 22:41:53 kernel: FPM Pool 0: invalid token 0x01b50000 freed
Jul 15 22:42:09 kernel: FPM Pool 0: invalid token 0x018a0000 freed
Jul 15 22:46:31 kernel: FPM Pool 0: invalid token 0x00928000 freed
Jul 15 22:46:31 kernel: FPM Pool 0: invalid token 0x029b8000 freed
Jul 15 22:48:04 kernel: FPM Pool 0: invalid token 0x01f50000 freed
Jul 15 22:48:22 kernel: FPM Pool 1: invalid token 0x20d10000 freed
Jul 15 22:49:47 kernel: FPM Pool 1: invalid token 0x21130000 freed
Jul 15 23:00:02 kernel: FPM Pool 0: invalid token 0x01f50000 freed
Jul 15 23:01:22 kernel: FPM Pool 0: invalid token 0x01c40000 freed
Jul 15 23:13:28 kernel: FPM Pool 0: invalid token 0x00e08000 freed
Jul 15 23:13:34 kernel: FPM Pool 1: invalid token 0x20378000 freed
Jul 15 23:16:35 kernel: FPM Pool 0: invalid token 0x016b8000 freed
Jul 15 23:21:38 wlceventd: WLCEVENTD wlceventd_proc_event(401): eth6: Disassoc B0:19:C6:99:41:E7, status: 0, reason: Disassociated because sending station is leaving (or has left) BSS (8)
Jul 15 23:22:50 kernel: FPM Pool 1: invalid token 0x20dd8000 freed
Jul 15 23:26:00 kernel: FPM Pool 0: invalid token 0x02118000 freed
Jul 15 23:34:45 kernel: FPM Pool 0: invalid token 0x00f60000 freed
Jul 15 23:37:48 kernel: FPM Pool 1: invalid token 0x219e0000 freed
Jul 15 23:38:04 kernel: FPM Pool 1: invalid token 0x217f0000 freed
Jul 15 23:48:12 kernel: FPM Pool 1: invalid token 0x20868000 freed
Jul 15 23:53:14 kernel: FPM Pool 1: invalid token 0x21588000 freed
Jul 15 23:53:19 kernel: FPM Pool 0: invalid token 0x00d10000 freed
Jul 15 23:55:11 kernel: FPM Pool 0: invalid token 0x00da8000 freed
Jul 15 23:58:31 kernel: FPM Pool 0: invalid token 0x00510000 freed
Jul 15 23:59:45 kernel: FPM Pool 0: invalid token 0x00d70000 freed
Jul 16 00:03:14 kernel: FPM Pool 1: invalid token 0x21d40000 freed
Jul 16 00:06:18 kernel: FPM Pool 0: invalid token 0x01ef0000 freed
Jul 16 00:08:21 kernel: FPM Pool 1: invalid token 0x20980000 freed
Jul 16 00:26:14 kernel: FPM Pool 1: invalid token 0x21b50000 freed
Jul 16 00:46:33 kernel: FPM Pool 1: invalid token 0x21e00000 freed
Jul 16 00:46:51 kernel: FPM Pool 1: invalid token 0x22078000 freed
Jul 16 00:55:19 kernel: FPM Pool 1: invalid token 0x21ac8000 freed
Jul 16 00:55:30 kernel: FPM Pool 0: invalid token 0x01a18000 freed
Jul 16 01:09:15 kernel: FPM Pool 1: invalid token 0x21138000 freed
Jul 16 01:11:08 kernel: FPM Pool 1: invalid token 0x21798000 freed
Jul 16 02:04:51 kernel: FPM Pool 0: invalid token 0x00a48000 freed
Jul 16 02:07:53 kernel: FPM Pool 0: invalid token 0x01090000 freed
Jul 16 02:28:18 kernel: FPM Pool 1: invalid token 0x21050000 freed
Jul 16 03:00:44 kernel: FPM Pool 0: invalid token 0x00b38000 freed
Jul 16 03:10:36 kernel: FPM Pool 1: invalid token 0x225f0000 freed
Jul 16 03:10:36 kernel: FPM Pool 0: invalid token 0x01968000 freed
Jul 16 03:36:46 kernel: FPM Pool 0: invalid token 0x01f78000 freed
Jul 16 03:38:15 kernel: FPM Pool 0: invalid token 0x00870000 freed
Jul 16 03:38:54 wlceventd: WLCEVENTD wlceventd_proc_event(401): eth6: Disassoc 38:2B:78:03:B4:AC, status: 0, reason: Disassociated because sending station is leaving (or has left) BSS (8)
Jul 16 03:45:03 kernel: FPM Pool 0: invalid token 0x01668000 freed
Jul 16 03:46:44 kernel: FPM Pool 1: invalid token 0x21338000 freed
Jul 16 03:50:21 kernel: FPM Pool 0: invalid token 0x02070000 freed
Jul 16 03:53:37 kernel: FPM Pool 0: invalid token 0x00e68000 freed
Jul 16 03:56:46 kernel: FPM Pool 0: invalid token 0x01758000 freed
Jul 16 03:58:30 kernel: FPM Pool 1: invalid token 0x209c8000 freed
Jul 16 03:58:48 kernel: FPM Pool 1: invalid token 0x20f80000 freed
Jul 16 04:03:30 kernel: FPM Pool 1: invalid token 0x20f40000 freed
Jul 16 04:03:36 kernel: FPM Pool 0: invalid token 0x02328000 freed
Jul 16 04:05:41 kernel: FPM Pool 0: invalid token 0x02d78000 freed
Jul 16 04:06:54 kernel: FPM Pool 1: invalid token 0x21438000 freed
Jul 16 04:06:54 kernel: FPM Pool 0: invalid token 0x00968000 freed
Jul 16 04:06:59 kernel: FPM Pool 1: invalid token 0x20798000 freed
Jul 16 04:10:08 WATCHDOG: [FAUPGRADE][auto_firmware_check:(6084)]period_retry = 0
Jul 16 04:10:09 WATCHDOG: [FAUPGRADE][auto_firmware_check:(6110)]retrieve firmware information
Jul 16 04:10:09 WATCHDOG: [FAUPGRADE][auto_firmware_check:(6124)]no need to upgrade firmware
Jul 16 04:10:25 kernel: FPM Pool 0: invalid token 0x02190000 freed
Jul 16 04:10:38 WATCHDOG: [FAUPGRADE][auto_firmware_check:(6084)]period_retry = 1
Jul 16 04:10:39 WATCHDOG: [FAUPGRADE][auto_firmware_check:(6110)]retrieve firmware information
Jul 16 04:10:39 WATCHDOG: [FAUPGRADE][auto_firmware_check:(6124)]no need to upgrade firmware
Jul 16 04:11:08 WATCHDOG: [FAUPGRADE][auto_firmware_check:(6084)]period_retry = 2
Jul 16 04:11:09 WATCHDOG: [FAUPGRADE][auto_firmware_check:(6110)]retrieve firmware information
Jul 16 04:11:09 WATCHDOG: [FAUPGRADE][auto_firmware_check:(6124)]no need to upgrade firmware
Jul 16 04:15:35 kernel: FPM Pool 1: invalid token 0x21380000 freed
Jul 16 04:17:20 kernel: FPM Pool 0: invalid token 0x00bd0000 freed
Jul 16 04:31:19 kernel: FPM Pool 0: invalid token 0x01090000 freed
Jul 16 04:36:22 kernel: FPM Pool 0: invalid token 0x00cf0000 freed
Jul 16 04:36:28 kernel: FPM Pool 0: invalid token 0x01ff8000 freed
Jul 16 04:36:46 kernel: FPM Pool 1: invalid token 0x21988000 freed
Jul 16 04:38:21 kernel: FPM Pool 0: invalid token 0x00428000 freed
Jul 16 04:41:37 kernel: FPM Pool 1: invalid token 0x20538000 freed
Jul 16 04:42:55 kernel: FPM Pool 0: invalid token 0x00338000 freed
Jul 16 04:44:40 kernel: FPM Pool 1: invalid token 0x201b0000 freed
Jul 16 04:47:22 kernel: FPM Pool 1: invalid token 0x20a60000 freed
Jul 16 04:49:38 kernel: FPM Pool 0: invalid token 0x00a70000 freed
Jul 16 04:51:29 kernel: FPM Pool 0: invalid token 0x01678000 freed
Jul 16 04:54:17 kernel: FPM Pool 0: invalid token 0x02950000 freed
Jul 16 04:59:57 kernel: FPM Pool 1: invalid token 0x223d0000 freed
Jul 16 05:03:06 kernel: FPM Pool 1: invalid token 0x20ef0000 freed
Jul 16 05:03:06 kernel: FPM Pool 0: invalid token 0x004c0000 freed
Jul 16 05:08:17 kernel: FPM Pool 0: invalid token 0x00880000 freed
Jul 16 05:09:24 kernel: FPM Pool 1: invalid token 0x210c8000 freed
Jul 16 05:12:55 kernel: FPM Pool 0: invalid token 0x01640000 freed
Jul 16 05:16:10 kernel: FPM Pool 0: invalid token 0x02778000 freed
Jul 16 05:16:43 kernel: FPM Pool 1: invalid token 0x20478000 freed
Jul 16 05:19:33 kernel: FPM Pool 1: invalid token 0x20218000 freed
Jul 16 05:24:52 kernel: FPM Pool 1: invalid token 0x218b0000 freed
Jul 16 05:26:26 kernel: FPM Pool 1: invalid token 0x20cc0000 freed
Jul 16 05:27:50 kernel: FPM Pool 1: invalid token 0x21228000 freed
Jul 16 05:28:18 kernel: FPM Pool 1: invalid token 0x22818000 freed
Jul 16 05:31:27 kernel: FPM Pool 1: invalid token 0x204c8000 freed
Jul 16 05:34:19 kernel: FPM Pool 0: invalid token 0x01c70000 freed
Jul 16 05:46:24 kernel: FPM Pool 1: invalid token 0x22948000 freed
Jul 16 05:51:30 kernel: FPM Pool 0: invalid token 0x01ab8000 freed
Jul 16 05:55:18 kernel: FPM Pool 0: invalid token 0x00a38000 freed
Jul 16 05:55:24 kernel: FPM Pool 1: invalid token 0x20998000 freed
Jul 16 05:55:29 kernel: FPM Pool 1: invalid token 0x21bf8000 freed
Jul 16 05:55:29 kernel: FPM Pool 1: invalid token 0x22470000 freed
Jul 16 06:00:08 kernel: FPM Pool 1: invalid token 0x21880000 freed
Jul 16 06:05:30 kernel: FPM Pool 0: invalid token 0x024d8000 freed
Jul 16 06:10:36 kernel: FPM Pool 0: invalid token 0x00478000 freed
Jul 16 06:18:52 kernel: FPM Pool 1: invalid token 0x20d00000 freed
Jul 16 06:19:15 kernel: FPM Pool 1: invalid token 0x21728000 freed
Jul 16 06:22:18 kernel: FPM Pool 1: invalid token 0x204f8000 freed
Jul 16 06:24:34 kernel: FPM Pool 0: invalid token 0x01568000 freed
Jul 16 06:26:15 kernel: FPM Pool 0: invalid token 0x01cd0000 freed
Jul 16 06:26:15 kernel: FPM Pool 1: invalid token 0x21860000 freed
Jul 16 06:29:09 kernel: FPM Pool 0: invalid token 0x006f0000 freed
Jul 16 06:30:53 kernel: FPM Pool 1: invalid token 0x20968000 freed
Jul 16 06:34:24 kernel: FPM Pool 1: invalid token 0x22b50000 freed
Jul 16 06:37:40 kernel: FPM Pool 1: invalid token 0x20df0000 freed
Jul 16 06:39:20 kernel: FPM Pool 0: invalid token 0x02aa8000 freed
Jul 16 06:41:17 kernel: FPM Pool 0: invalid token 0x01d58000 freed
Jul 16 06:46:49 kernel: FPM Pool 1: invalid token 0x215c0000 freed
Jul 16 06:51:43 kernel: FPM Pool 0: invalid token 0x00418000 freed
Hi, if by 'normal' you mean that they appear in other users of the same router, then yes. I can see these log lines in my rt-ax88 also. What is not clear is whether these are supposed to appear and are some kind of garbage collection for 'old' not used blocks or if they denote that something is not working right.
Hi, I am observing that with 384.13 merlin alpha firmware these 'invalid token' lines are much fewer than with previous releases. Most likely related to the newer base firmware (official 384.6210).
I am on the latest ASUS firmware. The router is still quite unstable and drops connections, loses WiFi with clients and needs to be rebooted often. I have temporarily changed back to my ac3100
Please write the specific version number, since "latest" is a very subjective thing. More than once I've seen people believe they were on the latest version when in fact they weren't.
IF you are really on 384.6210 firmware then definetly I am getting much better behavior (note that I am using Merlin's code, but it is based on 6210 official firmware also). What are your wifi configuration parameters ? do you use airtime fairness/beanforming options ? what about AX features and/or 160Mhz band usage ? I am very conservative on those. (note that the difference may be caused by many other things, some of them such as interference, which can not be controlled much)
Hi, If you still have the problem on 3.0.0.4.384.6210 firmware
You can send the feedback mail by the following step.
Administration / Feedback / Enable Extra information for debugging / Send
And let me know your mail address. We will try to find the problem from your log.
Thank you.
Thank you all for your help.
FW 3.0.0.4.384.6210
for AX this is disabled and 5ghz is 80mhz .
I will send in the feedback within the router.
