Odd messages in logs
AdrianH
Hi
Anybody shed some light on the below error. My wireless devices started to disconnect, had to hard reboot router and checked the logs and saw this.
Running Merlin 388.2_2
Aug 8 18:43:36 Asus-RT-AX88U kernel: FPM Pool 1: invalid token 0x20ea8000 freed
Aug 8 18:43:36 Asus-RT-AX88U kernel: FPM Pool 1: ISR timer is enabled. There could be multiple occurrences of the reported issue
Aug 8 18:43:36 Asus-RT-AX88U kernel: FPM Pool 0: invalid token 0x02770000 freed
Aug 8 18:43:36 Asus-RT-AX88U kernel: FPM Pool 0: ISR timer is enabled. There could be multiple occurrences of the reported issue
Aug 8 18:43:37 Asus-RT-AX88U kernel: FPM Pool 0: invalid token 0x02788000 freed
Aug 8 18:43:37 Asus-RT-AX88U kernel: FPM Pool 0: ISR timer is enabled. There could be multiple occurrences of the reported issue
Aug 8 18:43:37 Asus-RT-AX88U kernel: FPM Pool 1: invalid token 0x20eb0000 freed
