Greetings all.. I have been scouring Google for the last 2 hrs to no avail, so I am posting at your mercy. I have updated my Asus rt-n56u to the latest Padavan firmware, so that I may create an "always on" vpn connection from my router to my vpn service (airvpn).
I have all the configuration right and I can see in the logs that the connection is created successfully. I can even ping from within the router to the vpn remote gateway with success.
I cannot however connect to anywhere on the internet from any LAN clients (i.e. my machines are on the 192.168.1.0/24). I have gotten DNS to work for those clients (i.e. they properly lookup hostnames), but obviously any TCP connections don't get passed through the tunnel.
So my question is, is there some sort of iptables/masquerade settings I have to run after the fact to "forward" all packets from the 192.168.1.0/24 subnet through the VPN tunnel created by the router? I was under the impression that once you had everything configured via the GUI that was it, but from searching the net it seems that there are iptables rules I may/may not have to set up.
I have actually tried these but running a "iptables -L" after the fact shows no changes in the iptables configurations, almost like it's just ignoring the iptables commands.
Thanks in advance!
Thanks in advance!
