R7000 Speed Limitted 200 mbps
danielwalbr
Hello. I have an R700 using the latest Asuswrt-Merlin 386.2_4 firmware.
In the last week I changed my internet speed to 500 mps. After this upgrade I realized that even on the cable the speed was limited to 200 mpbs. Reading on the forum I found an instruction to make a hardware resset.
After the hardware reset I can have the speed normally 500 mpbs. However, if I turn off the router or need to do any restart (for example to create a guest network) I will be back with a speed of 200 mbps.
I've tried to go back to the previous firmware version, reset the factory settings, but the problem always remains the same.
Can someone help me?
Thank´s
You are using illegal firmware. You will get no support here.
