[R7000] Xvortex questions
doubleroll
Anyone using xvortex on R7000 does it have an option for jumbo frames for the LAN ports?
Sent from my iPad using Tapatalk HD
I just bought an R7000 a little over a week ago and loaded version 55.2 of Xvortex. Found a few bugs at least with my set up WAN LED doesn't light up, 5ghz band would either intermittently disappear altogether or when it did work would not transmit the SSID. Also, the 2.4ghz band was erratic and weaker than the Asus N66u I originally had installed . After a few setting changes and resets I gave up and went back tho the Netgear firmware, updated to the latest version and now everything is running perfectly and wireless strength is strong and consistant.
Yes, it supports jumbo frames
