[R7800/Voxel/Entware] How to compile iprange
HELLO_wORLD
I try to compile iprange: https://github.com/firehol/iprange
I installed Entware, then make, gcc...
No success. I am not familiar with cli *nix compiling...
Is it possible to compile this for R7800 ( @Voxel firmware), and how could I do that? I was not able to find a binary already compiled for armv7l, but there are binaries for FreeBSD armv7 for example.
Since I am no expert in *nix compilation, I don’t know if this iprange is standalone or requires some specific kernels...
iprange is a little utility that is part of FireHOL, and FireHOL is available on openwrt, so I suppose it is possible to compile just iprange (or get an armv7l binary working on R7800 somewhere).
Any ideas?
I can't remember which entware packages I installed in the past, so I might miss a few.
Also not sure if all the packages from the 2nd opkg install command are needed.
But this should get you somewhere:
/opt/bin/opkg install gcc automake
/opt/bin/opkg install busybox ldd make gawk sed
cd /opt/root
git clone https://github.com/firehol/iprange
cd iprange
./autogen.sh
chmod +x install-sh
./configure --prefix=/opt --disable-man
make
make install
(the command "chmod +x install-sh" normally also should not be required, but for some reason in this case install-sh was not executable)
at least it executes on my R7800, but not sure how to further test:
root@R7800:/$ /opt/bin/iprange --version
iprange 1.0.5_master
Copyright (C) 2015-2017 Costa Tsaousis for FireHOL (Refactored and extended)
Copyright (C) 2004 Paul Townsend (Adapted)
Copyright (C) 2003 Gabriel L. Somlo (Original)
License: GPLv2+: GNU GPL version 2 or later <http://gnu.org/licenses/gpl2.html>.
This program comes with ABSOLUTELY NO WARRANTY; This is free software, and
you are welcome to redistribute it under certain conditions;
See COPYING distributed in the source for details.
alternatively, to build the latest stable version:
/opt/bin/opkg install gcc tar
cd /opt/root
wget https://github.com/firehol/iprange/releases/download/v1.0.4/iprange-1.0.4.tar.bz2
tar -xjvf iprange-1.0.4.tar.bz2
cd iprange-1.0.4
make
make install
cd /opt/root
cd iprange-1.0.4
make
make install
It does not work for me:
root@HERMES:/tmp/mnt/sda1/entware/root/iprange-1.0.4$ ./configure --prefix=/opt --disable-man
checking whether to enable maintainer-specific portions of Makefiles... no
checking for a BSD-compatible install... ./install-sh -c
checking whether build environment is sane... yes
checking for a thread-safe mkdir -p... ./install-sh -c -d
checking for gawk... no
checking for mawk... no
checking for nawk... no
checking for awk... awk
checking whether make sets $(MAKE)... no
checking build system type... armv7l-unknown-linux-gnueabihf
checking host system type... armv7l-unknown-linux-gnueabihf
checking for gcc... no
checking for cc... no
checking for cl.exe... no
configure: error: in `/opt/root/iprange-1.0.4':
configure: error: no acceptable C compiler found in $PATH
See `config.log' for more details
And from git, it does not either:
root@HERMES:/tmp/mnt/sda1/entware/root$ /opt/bin/git clone https://github.com/firehol/iprange
Cloning into 'iprange'...
remote: Enumerating objects: 267, done.
remote: Total 267 (delta 0), reused 0 (delta 0), pack-reused 267
Receiving objects: 100% (267/267), 131.69 KiB | 263.00 KiB/s, done.
Resolving deltas: 100% (137/137), done.
root@HERMES:/tmp/mnt/sda1/entware/root$ cd iprange
root@HERMES:/tmp/mnt/sda1/entware/root/iprange$ ./autogen.sh
./autogen.sh: ./autogen.sh: 2: autoreconf: not found
Seems like scripts in iprange (configure.sh or autogen.sh are not aware to use /opt/).
what does your $PATH look like?
it should start with /opt/bin:/opt/sbin, so that it finds the entware binaries
On my R7800 I have added a line into /root/.profile so that it always imports the /opt/etc/profile from entware, when I login via ssh.
(actually I added it into the entware post-mount.sh, so that it also gets re-added after flashing a new firmware, so that is probably why I forgot)
if [ ! -f /root/.profile ]; then
        echo '. /opt/etc/profile' > /root/.profile
        chown root.root /root/.profile
fi
That’s it.
I do not imports the /opt directories in /root/.profile, as Voxel does not mention that in his readme... I thought it was deliberate therefore I avoided to do so.
However, changing autogen-sh, configure and Makefile by adding an export at the beginning worked like a charm, so thank you so much!!
fi
Well, it was one of the first things I did, because I hated typing the full paths to entware...
And I haven't noticed any strange things. Only in rare case I want to call a stock executable, but then I'll type the full path to that one.
Also, in the changes.log, in the list of changes for 1.0.2.59SF Voxel did mention:
16. /etc/profile default profile is changed (no PATH for /opt/bin:/opt/sbin).
Entware users should set the PATH for Entware in /root/.profile file.
