Raspberry Pi 5 16GB Starter Kit (UK) £83.78
BreakingDad
Raspberry Pi 5 16GB Starter Kit (UK) CPC FARNELL)
Product Overview​
This beginner-friendly kit is the perfect introduction to the Raspberry Pi 5 and includes all the essentials you need to get up and running with the Raspberry Pi 5! This kit includes a Raspberry Pi 5 (16GB model) with active cooler, 32GB MicroSD card with Pi OS software as well as colour coded HDMI lead, case and 5A USB-C power supply.
  • System on chip Broadcom BCM2712, 2.4GHz quadcore 64-bit ARM Cortex-A76 with 512KB L2 cache and 2MB shared L3 cache
  • 16GB LPDDR4X-4267 SDRAM
  • Dual 4K 60Hz HDMI display output with HDR support
  • Dual band 2.4GHz and 5.0GHz 802.11ac WiFi
  • Bluetooth 5.0 / Bluetooth Low Energy (BLE)
  • MicroSD card slot, with support for high-speed SDR104 mode
  • 2x USB 2.0 ports and 2x USB 3.0 ports supporting simultaneous 5Gb/s operation
  • Gigabit Ethernet, with PoE+ support (requires separate PoE+ HAT)
  • PCI-Express 2.0 x1 interface for fast peripherals (requires separate M.2 HAT or other adaptor)
  • Raspberry Pi standard 40-pin GPIO header
  • Real-time clock (RTC), powered from external battery
  • Onboard power button
  • Colour coded micro HDMI lead, case and 5A USB-C power supply included
Applications​
Embedded Design & Development, Electronics Design, Hobby & Education, Communications & Networking, Consumer Electronics, IoT (Internet of Things)
Contents​
Raspberry Pi 5, active cooler, red/white case, 5A UK power supply, 1m micro HDMI cable, 32GB MicroSD card with Pi OS and getting started booklet
