RBR50+Voxel WAN connection capped at 100mbs
lummux
Not sure what's changed, but connection speed is now capped at 100mbs between my sb8200(amber) and the orbi. I've only been using Voxel's firmware a month or so, but after I flashed, my speeds were consistent with the OEM firmware (270+Mbs).
ifconfig:
Bash:
br0       Link encap:Ethernet  HWaddr xx:xx:xx:xx:xx:xx
          inet addr:192.168.1.1  Bcast:192.168.1.255  Mask:255.255.255.0
          inet6 addr: fe80::a02:8eff:fe96:bd3b/64 Scope:Link
          UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1
          RX packets:1093278 errors:0 dropped:0 overruns:0 frame:0
          TX packets:1292005 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:0
          RX bytes:137199152 (130.8 MiB)  TX bytes:495416322 (472.4 MiB)
brwan     Link encap:Ethernet  HWaddr xx:xx:xx:xx:xx:xx
          inet addr:xxx.xxx.xxx.xxx  Bcast:255.255.255.255  Mask:255.255.255.0
          inet6 addr: fe80::a02:8eff:fe96:bd3c/64 Scope:Link
          RX packets:1022106 errors:0 dropped:0 overruns:0 frame:0
          TX packets:777860 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:430605924 (410.6 MiB)  TX bytes:116371603 (110.9 MiB)
eth0      Link encap:Ethernet  HWaddr xx:xx:xx:xx:xx:xx
          RX packets:1022515 errors:0 dropped:0 overruns:0 frame:0
          TX packets:776867 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:1000
          RX bytes:444979634 (424.3 MiB)  TX bytes:116257995 (110.8 MiB)
eth1      Link encap:Ethernet  HWaddr xx:xx:xx:xx:xx:xx
          UP BROADCAST RUNNING ALLMULTI MULTICAST  MTU:1500  Metric:1
          RX packets:843606 errors:0 dropped:0 overruns:0 frame:0
          TX packets:1035539 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:117661440 (112.2 MiB)  TX bytes:289382298 (275.9 MiB)
ethtool on eth0:
Settings for eth0:
    Supported ports: [ ]
    Supported link modes:   Not reported
    Supported pause frame use: No
    Supports auto-negotiation: No
    Supported FEC modes: Not reported
    Advertised link modes:  100baseT/Full
    Advertised pause frame use: Symmetric Receive-only
    Advertised auto-negotiation: Yes
    Advertised FEC modes: Not reported
    Speed: 100Mb/s
    Duplex: Full
    Port: Twisted Pair
    PHYAD: 0
    Transceiver: internal
    Auto-negotiation: off
    MDI-X: Unknown
    Supports Wake-on: d
    Wake-on: d
    Current message level: 0x00000000 (0)
    Link detected: yes
If I force eth0 to 1000, I get "Speed: Unknown!".
Orbi is directly attached to modem. Tried multiple cat5e cables that will connect other devices at 1G.
Regards,
-lee
Just removed the orbi and connecting directly to the sb2000 gives me a 1G(green) link. So it really seems like it is the orbi port that is having the issue.
Regards,
-lee
Just downgraded to oem V2.7.1.60. The wan port now connects @1G. I'll have to wait until later tonight to do a factory reset and flash to the latest voxel. If I do it now, then the whole house screams, "Is the internet down?"
Regards,
-lee
Latest Voxel is based off of the NETGEAR 2.5.x code set; hence, do NOT flash Voxel if anything higher is installed.
You mentioned you have 2.7.x NETGEAR installed. DO NOT install Voxel 9.2.5.x! You will need to downgrade to stock NETGEAR 2.5.2.4 first.
