Reboot problems with tntfs error in logs
Plum117
Hi guys,
I'm new in this forum. For some weeks now, I'm having some restart issues with my Asus RT-AC87U. After some research, I found today the ASUSWRT-MERLIN firmware that would be more stable so I install it few hours ago (pretty cool thing by the way). In the next weeks I will see if my router is more stable.
Meanwhile, I was also seeing some issue with my usb drive (Seagate see below for specs) which I would like to resolve since it could be one of the factor causing my reboots. I read on other posts that it could be better to have some self powered usb drive but I'm not sure if this is really the problem. Also, other post spoke about formating with EXT3/4 maybe it could help but before doing that I would like to know for sure it will fix my problem.
So anyone could know what is causing ntfs_prepare_pages_for_non_resident_write() tntfs error?
Note: I also upload my router sys log if anyone can found something interesting to help me!
Seagate Backup Plus Portable Black 1TB Drive (STBU1000203):
http://www.seagate.com/ca/en/suppor...s/portable-hard-drives/backup-plus-usm/#specs
ar 13 00:09:42 kernel: scsi 0:0:0:0: Direct-Access Seagate Backup+ RD 0412 PQ: 0 ANSI: 6
Mar 13 00:09:42 kernel: sd 0:0:0:0: Attached scsi generic sg0 type 0
Mar 13 00:09:45 kernel: sd 0:0:0:0: [sda] Spinning up disk......ready
Mar 13 00:09:45 kernel: sd 0:0:0:0: [sda] 1953525167 512-byte logical blocks: (1.00 TB/931 GiB)
Mar 13 00:09:45 kernel: sd 0:0:0:0: [sda] Write Protect is off
Mar 13 00:09:45 kernel: sd 0:0:0:0: [sda] Assuming drive cache: write through
Mar 13 00:09:45 kernel: sd 0:0:0:0: [sda] Attached SCSI disk
Mar 13 00:09:45 usb: USB /dev/sda1(ntfs) failed to mount At the first try!
Mar 13 00:09:46 usb: USB ntfs fs at /dev/sda1 mounted on /tmp/mnt/Seagate_Backup_Plus_Drive.
Mar 13 00:09:47 rc_service: hotplug 9513:notify_rc restart_nasapps
Mar 13 00:09:47 iTunes: daemon is stopped
Mar 13 00:09:47 FTP Server: daemon is stopped
Mar 13 00:09:48 Samba Server: smb daemon is stopped
Mar 13 00:09:48 kernel: gro disabled
Mar 13 00:09:48 Timemachine: daemon is stopped
Mar 13 00:09:48 kernel: gro enabled with interval 2
Mar 13 00:09:49 Samba Server: daemon is started
Mar 13 00:09:51 kernel: tntfs error (device sda1, pid 9566): ntfs_prepare_pages_for_non_resident_write(): Failed (error 5).
Mar 13 00:09:52 kernel: tntfs error (device sda1, pid 9566): ntfs_prepare_pages_for_non_resident_write(): Failed (error 5).
