Recommendations for an AP
Notconnected
I want to hard wire an access point to my switch in order to access all my devices wirelessly at home.
It would seem to do so I require and AP.
Am looking at this one from Vigor, https://www.draytek.com/products/vigorap-905#nav-overview
From what I can tell it will do VLAN 's and Multiple SSID's and has plenty of ports.
Is there any other recommendations for other AP 's, on the European side of things.
WiFi 6 will be fine for me, I will be using 2.4 mostly anyway.
I tried a Raspberry Pi based AP running RaspAP, it was fine when it worked, but connecting to it
was a nightmare, I had a USB dongle connected to it that worked fine on other devices, RaspAP
could find and use it, there was a driver for it, and it worked perfectly on the Pi devices, but for
some reason was an absolute hit and miss when trying to connect to it, the Pi's unboard WiFi
was simpy too weak to use for an AP.
I preffer an AP with local admin via a browser, no apps or special controllers.
What else besides a switch, does your network include ? Brand/model # please.
Do you intend to use VLANs ?
