Solved remedy? kernel: update bss - wpa_ie and wpa2_ie is not null
consorts
new rt-ax88u-pro hw.v3.x 3006.102.4
5.0ghz devices with 65-70db will disconnect around the time i see;
Jul 30 21:13:44 kernel: update bss - wpa_ie and wpa2_ie is not null
Jul 30 21:14:31 hostapd: wl1.2: STA ee:ab:ab:ab:ab:27 WPA: did not use EAPOL-Key descriptor version 0 as required for AKM-defined cases
update: i noticed i had wpa/wpa2 so i changed it to wpa2
i try ch.36 20/40/80 if lower range help penetrate further.
will edit here in an hour in hopes my 5.0 and kernel is calm.
ok, hour's up, i gained -2dBm using the lower channel
and am not throwing any more kernel WPA errors
while 4k tv was streaming the same video again,
so i guess the worst of my problems are resolved.
