Remote Access ?
Where is the option to allow REMOTE ACCESS on the AC68U software?
Thank you ...
Remote access to what specifically? AiCloud? Your LAN through a VPN tunnel? The web interface?
Thanks for your reply...
I want to access cameras or the router from another computer not on the same network.
Then you will need to configure a VPN server, either the simple to use PPTPD, or the more secure OpenVPN. Both are configured under the VPN section.
