YazFi Remove YazFi on New 3006.xxx.x Firmware
MusicLover2112
As some folks are aware YazFi is no longer compatible with Asuswrt-Merlin 3006 series firmware. I would like to remove this AddOn but not sure how to that because it won't load to allow the removal. Is there an AMTM script that can remove it? Thank you!
Uninstall YazFi using it's normal uninstall option in the YazFi CLI before you flash the Asus-Merlin 3006 firmware. Use option Z in the YazFI CLI. Really though the easiest way is to just do a hard factory reset after flashing the 3006 firmware. That should clear out the JFFS folder of any of the addon scripts and reset the router to default settings for the 3006 firmware. Some will recommend doing a reset anyway when flashing from 3004 to 3006 due to the number of changes and new features in 3006 firmware.
There was some earlier discussion on manually removing YazFi files in 3006 at this post (and my reply to it):
https://www.snbforums.com/threads/is-yazfi-gone.94683/#post-955243
@MusicLover2112 You could try the uninstall switch? Works for me without downgrading the firmware.
sh /jffs/scripts/YazFi uninstall
Apologies for the late response and for not being clear that I had already updated to the 3006 firmware (and thus couldn't enter the YazFi's menu system). Thanks for the solution, ExtremeFiretop - it worked perfectly.
