Solved Removed
You won’t get a valid result scanning from the LAN side of the router (192.168.1.1). You need to scan your WAN IP. Is 1.1 the default IP of the AX86U or did you have to change it from 50.1 to 1.1?
Another guy was reporting port forwarding problems in this thread:
