Hello,
recently I have switched from stock firmware to Merlin 388.2 on my RT-AX58U
It was a clean upgrade with restoring to default values, and everything was put in manually.
Unfortunately, I get a lot of de-authorisations like this on my WiFi 5Ghz AX client:
What I did try so far:
- connecting to a newly created guest network, but its the same
- switched from 160MHz channel width do 80Mhz
- updated the drivers on my Intel WiFi 6E AX211
At this moment my other AX client is away so I dont have the hardware to test it on.
But testing on a 2,4Ghz N client gives me similar result - a deconnection (client 64:70:02:08:38:9C)
Below the logs.
Most resent events of deconnection took place at about 13:06 13:47 14:12 14:35 and 14:41
Link_to_log_it_was_too_long_to_paste_here
Can anyone help me out a bit here? I don't really want to roll back to the stock firmware.
When it happens, I am unable to reconnect to the router for a few minutes.May 8 09:54:19 wlceventd: wlceventd_proc_event(494): eth6: Deauth_ind 888:2E:4F:F4:E8, status: 0, reason: Unspecified reason (1), rssi:-50
Below the logs.
