YazFi reporting minor issue to dev
DTS
I don't see an Issues section on the YazFi GitHub, so I'm reporting this here. This is obviously a trivial issue as help is available at https://github.com/jackyaz/YazFi
/tmp/home/root# /jffs/scripts/YazFi help
Command not recognised.
For a list of available commands run:  help
Lol. OK, tried it another way:
WebUI for YazFi is available at:
https://192.168.1.1:8443/user1.asp
1.    Apply YazFi settings
2.    Show connected clients using YazFi
3.    Edit YazFi config
4.    Edit Guest Network config (SSID + passphrase)
QR Code generation not supported.
u.    Check for updates
uf.   Update YazFi with latest version (force update)
d.    Generate YazFi diagnostics
e.    Exit YazFi
z.    Uninstall YazFi
Choose an option:  help
Please choose a valid option
It probably wasn't intended to be used that 2nd way, but I thought I should try, given the first message.
As said, it's not a problem for me as I just looked here: https://github.com/jackyaz/YazFi#readme
