Repurposing WD DL4100
nas_noob
I would like to know all available open source OSes (which can be used with WD).
I will be using DL4100 to play around - don't care about NAS capabilities to start with. I won't even mind installing normal Linux (if possible) and then configuring RAID and allowing network access.
If I'm successful I may want to do similar with EX (however I think this is bit harder due to ARM processor).
Welcome to the forums @nas_noob.
A (very) quick search brought up nothing in these forums for what you're searching for, nor on the general web.
Is this just for learning purposes? A simple Pi may be the better path here.
Oh I retired WD DL4100 and moved to TrueNAS with dedicated NAS system. So I've DL4100 on my hand.
Also I didn't find much info, so checking around.
It is for learning and changing few more WD systems.
I hope someone has some useful info for you then. :)
The WD series that you're working with are really good at being plain-jane nas units--and that's all I would use them as. You can load them up with ram on the cheap and then ssds for a fast network drive or put in a large 16TB+ drive as a backup to another nas (they're great in this capacity). The hardware of the 4000 series is seriously robust and always has been so it should last a long time.
Sometimes the best repurposing is to simply let it continue working. ;)
