Request a review on NetGear WNDR37AV
tipstir
Hey Tim,
Are you going to review this router? I had seen it today in BB store for $169 suppose to have some sort of DLNP from USB, so it might be more supportive to USB devices. Same WNPU, same RAM in the prior WNDR3700.
Well if you not testing it out the extra data is that the same Atheros 680MHz Atheros AR7161 MIPS 24K CPU, 64MB RAM, and 16MB except for the USB now supports HDTV with ReadySHARE USB port allows you stream video and music from a USB drive to media players, DLNA TVs with built-in DLNA media server. Same power as the WNDR3700 but now can handle the demands of HD streaming well on the box is said that. I don't know for $160 so you figure $120 MSR with retail cost to get the product into the store then tack on the extra $40 to the consumer.
More here on the netgear forum.. http://forum1.netgear.com/showthread.php?t=52714 got a guy works at BB so he can take some images of the WNDR3700 and WNDR37AV to show the difference, but it's with the DLNA compliant, WNDR37AV Wireless Router for Video and Gaming is designed for future standards in wide range of compatibility products. Compare also with the previous Netgear WNDR3700 Wireless –n gigabit router
rborth Asustor NAS New Forums request?? Suggestion Box 2
