www.snbforums.com
ok thanks. I want to just know about possibility of any future or in-progress working for supporting ASUS RT-AX55. anyway, thanks for your replay.![]()
[FAQ] READ ME FIRST before posting a question
Model support Q: Will you support the RT-xxxxxx that was just announced? A: See detailed answer in post #3. Q: Will you support router XYZ from this non-Asus manufacturer? A: No. Asuswrt-Merlin only targets Asus-supported models, due to both technical and legal reasons. Q: I'm having...www.snbforums.com
What a pity! Can't make a lite firmware? AC86U and better is too high end for me and not practical.To be blunt, the possibility of the RT-AX55 being supported by RMerlin is effectively nil.
With only 256MB of RAM, this 1.5-year-old model is crippled right from the start.
If you need an RMerlin-powered router, I suggest looking at something in the supported list instead.
About | Asuswrt-Merlin
Also, be sure to refer to the following link to make a better buying decision today.
Current Order of Recommended Routers Late 2021
So why is it so important to use Merlin?What a pity! Can't make a lite firmware? AC86U and better is too high end for me and not practical.
AX55 would be the most economical model AX
I think it's ASUS' product strategy reason. The AX55 is the cheapest router that ASUS is currently selling, so it doesn't take this product seriously.Merlin runs perfectly fine with 256 megs on AC68 variants, is there some reason why that's suddenly an issue on an AX router? I'd be more suspicious about the AX55 just because Asus themselves haven't updated the firmware for quite a while now: 2021-11-03 was the last official update.
for me, i want more DIYSo why is it so important to use Merlin?
Hello, I think many RT-AX55 Router owner need Asuswrt-Merlin firmware update for this router.
why is not possible? and when this update will be release for RT-AX55?
I second this recommendation. See my signature.Frankly, Merlin has stated that he can only handle a limited number of router models due to the effort to support each one. If you want to run Merlin, then purchase a model that supports it and use your existing router as an AI mesh node running stock code. This is a supported configuration.
I'll second your post, the RT-AC68U is ubiquitous and a rock solid router after all these years. In hindsight ASUS must realize they failed with planned obsolescence on this model.RT-AC68U variants are the most popular Asus routers and still actively supported by Asus. Very often they get firmware updates before much newer models. They are like the gold standard platform. This new AX router is just cheap market filler. Few years from now no one will remember it existed.
Agree with this.I found that the RT-AX55 works fine as a basic router for single person home connectivity.
One was replacing a 10 year old tp-link router that stopped working properly. 2018 was the last BIOS release.
The other was replacing a ASUS RT-AC3200 (EOL) that was having problems.
I paid $79.99 each for them and they have been working with no problems for those two people.
Welcome To SNBForums
