This is a naive question but one that I haven't seen discussed; I doubt it is unique to Asus routers (I've observed the same phenomenon with other routers), and I'm surprised more people don't comment on it.
My setup is this: I have an Asus AC-68U router running Asus Merlin. In addition to using the router's native wifi, I have two wifi access points directly wired to its ethernet ports for wifi coverage of remote points in my house. All of the wifi networks share the same SSIDs and authentication parameters, but they use different channels. I can roam from one to another without a problem. They are just dumb access points and rely on the 68U for DHCP, firewall, etc.
The problem I note is that certain apps on my smartphone (Google Hangouts is the worst offender; the Logitech Harmony Android app is another) seem to transiently lose connectivity when I roam from the router's wifi to one of the remote access points, though my phone maintains Internet access (e.g., I can access websites); eventually, however, everything sorts itself out by itself. My thought (sorry if this turns out to be an ignorant hypothesis) is that when the router receives a packet destined for my phone, which had initially connected over the router's native wifi, it routes the packet over its native wifi rather than routing it via the wired LAN to the remote AP my phone has roamed to. That is, it doesn't seem to know my phone has roamed from the router's wireless connection to (from the router's point of view) a wired connection. Eventually, the phone (or the app) makes itself known on the new interface, and everything works fine - maybe the routing table gets updated?
Is this explanation plausible? Any solution to this?
