Root login?
boxst
I wanted to change some of the web pages, but can't as all the files are read only apart from root.
I can't find the password, is there one?
How to change some of the web pages???
What pages do you want to change? The firmware configuration pages?
You ARE root on the router. Check this in telnet:
chief@RT-N66U:/tmp/home/[B]root[/B]# cd
chief@RT-N66U:/tmp/home/[B]root[/B]# pwd
[B]/root[/B]
You can also look into the passwd file:
chief@RT-N66U:/tmp/home/root# cat /etc/passwd
chief:x:[B]0:0[/B]:admin:/root:/bin/sh
If you want to change the firmware web pages, the answer is simple: You cannot to it!
Why? The firmware is read only and the web pages need to be change before compiling the firmware. :eek:
But: The Merlin firmware is open source, you can do the changes you want in the sources and then compile if yourself.
Look here for more details: https://github.com/RMerl/asuswrt-merlin
There is by sure a repository of the original Asus firmware, but I do not have it at hand to show you.
With kind regards
Joe :cool:
The filesystem is read-only because it's stored in flash. There are however ways to temporarily replace a file using a method calling mount bind. What this does is it lets you mount a file on top of another one. With the regular firmware this would require you to re-run the command manually every time you reboot however. The syntax looks pretty much like this:
mount -o bind /mnt/sda1/www_copy/Advanced_System_Content.asp /www/Advanced_System_Content.asp
That will make the file on your USB disk get mounted on top of the read-only version, allowing you to replace it, or modify and test your changes as you go.
Thank you for that.
I seem to have changed the wireless output to 500mw now by changing the validation in the ASP page. Now whether as you mention somewhere that is true or not and not a hardcoded restriction in the firmware is another matter...
Steve
Sorry didn't work
mkdir: can't create directory '/usr/share/GeoIP': Read-only file system
Sorry didn't work
You quoted a command that runs a mount command, and your error message refers to a mkdir command. I don't understand what you are trying to do here, sorry...
I'm trying to use GeoIP plugin to display country flags in RuTorrent. How can I create GeoIP directory and put GeoIP.dat in /usr/share file system (read only)?
You can't. You will need to find a way to tell GeoIP to look elsewhere for its database.
