root out of space -- tried factory reset from gui and clearing nvram
cuekay
Hello. I've been having issues with a number of services in entware running and during my investigation, found this:
admin@TM-AC1900:/tmp/home/root# df
Filesystem           1K-blocks      Used Available Use% Mounted on
/dev/root                28928     28928         0 100% /
devtmpfs                127752         0    127752   0% /dev
tmpfs                   127856       916    126940   1% /tmp
/dev/mtdblock4           64256      1716     62540   3% /jffs
Issues started with Transmission giving me errors and the service stopping. I uninstalled Transmission but saw the system log giving "insufficient disk space" errors and left me with the inability to nano edit a file without it giving me a memory error.
I was wondering how I can clear up some space as I had tried to factory reset from the webgui and also clearing nvram using the "mtd-erase2 nvram", which appeared to have worked in other respects in that the webgui refreshed to the setup page. Any help would be much appreciated.
root always shows as 100% in use (read only fs that contains the firmware). Don't see anything out of the ordinary.
The one you need to monitor if you are getting disk space messages is tmpfs.
