Hello,
I’ve got the following question:
What I am trying to establisch is to connect from outside (WAN) true my Asus VPN-server (client get 10.8.0.0 ip-adres from VPN-server) and connect to my entire inside lan network (192.168.2.0).
Set-up:
Modem service provider > Asus RT-AC 88U (latest Merlin firmware and amtm running).
3 x VPN client (always on).
VPN server-1 (always on).
Daily reboots enabled.
I can connect to the VPN server on the Asus RT-AC 88U.
Under Lan > route, I created a rule as following:
Netwerk/Host-IP Netmasker Gateway Metric Interface
10.8.0.0 255.255.255.0 0.0.0.0 1 all interfaces I select wil work.
Or:
10.8.0.0 255.255.255.0 192.168.2.0 1 all interfaces I select wil work.
First off all, I don’t know of this is the right rule but this works. But not for a long time. After a few hours and after a router reboot, I can’t reach the devices in the inside lan anymore.
The VPN-server is always working so that’s not the problem.
So where am I going wrong?
Thanks in advance.
Chief
Set-up:
Or:
Thanks in advance.
Chief
